Need help.
Need help.
Message 1 of 10
Need help.
Hi. For several days I have been struggling with the project,
and actually setting the dimensions so that only two main ones are dynamic
and the others match the main ones. My main dimensions that I wanted to be able to change myself
are height and width. The frame around the muntins and the muntins in the middle are to be solid
and the windows are to be dynamic and adapt to the changed dimensions.
There will be someone who will help me because I already have nerves. Thank you in advance.
I attach a link to the project although I don't know if I'm doing it right and it will work.
https://a360.co/39Paueq
Replies (9)
Message 2 of 10
TheCADWhisperer
File>Export and then Attach your *.f3d file here.
Message 3 of 10
I hope it's good now.
Regard.
Message 4 of 10
TheCADWhisperer
Too many dimensions.
Not enough constraints.
Back in a minute...
See Attached file.
Message 5 of 10
Yes, I know that there is a lot of everything but I do not know how to do it, I combine. I attach one more file because I have to add rays to the windows.
We managed to do it with two construction lines. But I just need to put the rays in the windows.
Message 6 of 10
TheCADWhisperer
Did you see the simplified example that I Attached to my previous response?
Message 7 of 10
ooo sorry i haven't seen anymore watching.
I do not know what to say. I think I am only tiny. I understand that you based it on construction ropes?
And of course thank you very much for your help.
Message 8 of 10
g-andresen
Become a friend with parametric design!
günther
Message 9 of 10
Wow great. You made me a little smarter. Once again, many thanks.
Message 10 of 10
Hi. I need a hint again. I'm sitting again and I can't find a way to solve it.
I mean putting numbers on the design but I want them to be dynamic just like the whole shape.
TheCADWhisperer you rescued me previously I will be grateful for your help again.
Thank you in advance for your time.
