need help with socket holder design
不适用
1,214 次查看
3 条回复
1 条消息(共 4 条)
不适用
so im trying to make a holder for my sockets. i start with  center rectangle, then make a smaller rectangle on the inside, then measure out the socket areas, then use the pipe tool to make the grooves.
The problem is when im done its never centered because i have to start at one end. what would be the best way to make that centered? if the grooves were all the same diameter, it would be easy, but they aren't.
hopefully that makes sense.
0 个赞
已接受的解答 (1)
1,215 次查看
3 条回复
回复 (3)
2 条消息(共 4 条)
etfrench
已接受的解答
Dimensions and User Parameters are your friend 高兴表情  Instead of the Pipe command, use a simple Extrude from the side:
ETFrench
3 条消息(共 4 条)
不适用
see, i miss obvious things like that. You are Phenomenal!
0 个赞
4 条消息(共 4 条)
不适用
forgive my ignorance. how do i create the parameter in that way to space the outside of the circles apart?
0 个赞
