Need help with drawing need to make openings on face like the first one in the
cerami2
cerami2
Need help with drawing need to make openings on face like the first one in the row .
i get error message: THE OPERATION FAILED. TRY ADJUSTING THE VALUES OR CHANGING THE INPUT GEOMETRY
any help would be appreciated
I have enclosed the file
jhackney1972
Your "model" is a bit strange, entirely made of surfaces.  Anyway, I used the Surface Trim command to open up each opening in the top surface.  I am hoping that is what you wanted.  Model is attached.
John Hackney, Retired
laughingcreek
I think you take a look at your modeling approach.  my first question is why are you using surfaces, and not solid bodies, at all?  second is why do you have so many different bodies?
I didn't attempt to recreate your exact model, but the attached example has all the same types of features that I think you where trying to achieve.  and it's WAY easier to both model and to make future edits.  take a look through the time line and see if you can't work out what's going on.
cerami2
Thank you for your  help I didn't know that tool did that .Thank you, I learned new something today.
Im trying to teach myself this program so i'm sure I will be back
