Hi All,
Let me lead with my Father in Law (FIL ) and myself are extreme novices to Autodesk / CNC / etc. He bought the toys and I'm trying to help figure them out, lol.
We're currently using Shapr3d to create the sketch and importing that sketch into Fusion 360 to create the machining process and .CNC file to use on the plasma table.
However, we've run into an issue. The lettering at the top of the image, especially the curves, is made up of entirely too many points and it's making the CNC table chew up the letters. I'm thinking this MAY have something to do with the translation between Shapr3d (which we have for his 3d printer, orginally) and Fusion 360.
I attempted to use the "text on path" feature in Fusion - which technically went OK, but the letters are not touching the rest of the original sketch and will not be connected to the rest of the metal piece when we cut it out.
Ideally, I'd like to just be able to drag the letters down a bit until they touch the outer edge of the rest arc and use the trim tool to clean it up, and be done with it. But we can't even figure out how to do that.
Any guidance / tips / etc on how to get the letters going around the curve AND have them touch the outer arc edge (so they'll stay when the plasma torch cuts out the outlines) would be greatly appreciated.
I've attached a few reference images. Happy Father's Day gents!
