Need help on simulation
Im trying to run a static stress simulation on the following.
https://imgur.com/a/JcsUfyQ
Since the body is large I've considered one fourth of it and proceeding with the simulation.
Is it necessary to mesh before solving as I'm stuck on 76% and its been quite some time since then .
TheCADWhisperer
Can you File>Export and then Attach your *.f3d file here?
Here you go
Now its showing the simulation cannot be stopped as the results are obtained and are being received.
Any idea what I should do ?
When I open the file, I dont see any result or anything.
TheCADWhisperer
I think you are trying to analyze too much at once.
I would idealize into much smaller portions of interest (and probably use a shell analysis tool rather than mesh tool).
Is shell analysis tool part of fusion 360 or is it like another software ?
Also what if I try to scale down the model ? Will that help. Currently the model is 11770mm * 1620mm .
Will scaling down help ?
