Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Need Help How to make a bubble heart
7 REPLIES 7
Message 1 of 8
smeharg
6736 Views, 7 Replies
   Hey Guys I have been banging my head for hours on this one. I can't seem to make a VERY Simple heart and then loft it or do the replace face thing or multiple other things I have tried.
   Why Is there no simple make a model face into a t-spline face. (I really want to rant but Im new to Fusion)
I have tried the create plane, and replace face thing but alas it does not give the desired results. I need the outline of the heart to be the constraining line not the "plane" square.
7 REPLIES 7
Message 2 of 8
TheCADWhisperer
in reply to: smeharg
This design has come up here several times over the past 4 yrs.
A search should turn up prior threads on the topic.
Can you File>Export and then Attach the *.f3d file of your attempt?
Edit: Hmm, well of course now I do a quick search and can't find the prior references.
Someone will come along and remember this and know the reference.
Message 3 of 8
smeharg
in reply to: TheCADWhisperer
Super Thanks for the reply! Here is my file. Imtrying to get the curve to go all the way to the edges with no walls.
Message 4 of 8
g-andresen
try it in Sculpt mode!
günther
Message 5 of 8
smeharg
in reply to: g-andresen
I have been in and out of sculpt mode. I believe my issue is I cant select the heart outline to use as a constraint so the sculpt doesnt do weird things to the edges.
Message 6 of 8
jeff_strater
here is one way to get a shape sort of like that, using surface Loft.
Jeff Strater
Engineering Director
Message 7 of 8
jeff_strater
in reply to: jeff_strater
just went back and looked at the image.  Didn't realize that this was not planar on the back, so I added another mirror, and tweaked the sketches a bit to get this:
and attached the model.
Jeff Strater
Message 8 of 8
smeharg
Geeze... sorry for the long reply, I thought I hit post the first time.
Thanks very much for the reply and video. I have several SVG files, not to complicated, heart, balloon etc. I was hoping to not have to Build each item separately. I will keep playing.
On a second note, That was perfect for another one I was doing.
Thanks again,
