my data panel is blank and I cant open or find any of my saved work
Message 1 of 9
Good day
I am a new user to fusion 360
after drawing for 3 hours I saved my work and tried to open my data panel to open another drawing.
My data panel is blank and unresponsive. I cant find any of my other saved files anywhere and cant open anything
Is there something I can do Or something I have done wrong ?
Replies (8)
Message 2 of 9
innovatenate
Autodesk Support
Autodesk Support
Welcome to the Fusion Community!
When you say the data panel is blank, is it black or white or is it just missing projects that you would expect to be there? Could you post a screenshot and/or share your diagnostic log files (see help menu for command)?
There's a couple of suggestions in the below links that may help.
Nathan Chandler
Principal Specialist
Message 3 of 9
it is white. and I am unable to load any drawings and I cant import drawings and the only way I can open a drawing is to draw something ,save it to my profile. then download that drawing
I have attached the diagnostic log .I will upload a screen shot now
Message 4 of 9
here is the screen shot
Message 5 of 9
AlexPetak_Autodesk
please try this:
- Close Fusion
- navigate into the folder with your A360 data : C:\<<current user>>\AppData\Local\Autodesk\Autodesk Fusion 360\<<your Autodesk ID guid name>>
- in this folder you should see subfolder "OfflineJS", delete whole this folder
- start Fusion again
Alex
Message 6 of 9
thank you that worked. it seems to be working fine now
Message 7 of 9
Message 8 of 9
AlexPetak_Autodesk
Just a question.
From Your log from 2/21 around 4:24 PM it looks like the Fusion was run two times at once.
Two Fusion instances running at the same time.
20170221T162452 I Graphics Card: NVIDIA GeForce GT 335M, Rating: Unknown, Workarounds: 0
20170221T162452 I OGS Device: VirtualDeviceDx11
Do You please remember what happened at that time?
Was the Fusion run twice by accident?
This info will help us to understand what happened, thank You.
Alex
Message 9 of 9
Yes I'm pretty sure it was by mistake.
Thank you again for helping me sort out the problem
