Multiple move copy
Multiple move copy
Multiple move copy
In the case of spiral stair treads.
Can I copy and move and rotate in a single operation for multiple treads.
At the moment I am modelling the lowest tread.
Then copying/moving that tread to the next level.
Then rotating it to suit the spiral.
Then repeating this process for each tread thereafter.
I,m assuming there is a more productive approach. Maybe someone can
point me in the right direction.
Thanks.
tim
josef.kucera
Hi @Anonymous,
this older thread may be help you:
http://forums.autodesk.com/t5/design-validate-document/patterning-by-translation-and-rotation/m-p/55...
Josef
Josef Kucera
Fusion QA
But as a novice at Fusion360, scripting is a bridge too far for me at the moment.
I,ve only used Fusion for the past couple of weeks.
Tim
josef.kucera
If you read through the whole thread you will notice that there are also other advices how to create a stairs parametrically in the Fusion...
Hope it helps.
Josef
Josef Kucera
Fusion QA
Thanks..
Other options are written by more knowledgeable Fusion advocates than I am.
I,m not up to speed on the parametric attributes or avenues in Fusion after only a couple of
weeks I,m afraid, but I,ll keep looking.
Tim
