Multiple Joints Same Component
e9_vito
e9_vito
I've been using fusion for a long time and I've run into this time and time again, but would always work around it with obscure methods.
I've attached a very basic assembly file that consists of two uniquely shaped parts with identical spaced thru holes in each of them. I would like to joint them together so that their thru holes align with each other. Dating myself, but with solidworks in 2015 I would simply click and mate. If they were indeed identical the operation would complete and I would go about my day. In fusion, I joint one and when I attempt to joint the other, I get the following error.
"the following assembly relationships already exist between the selected components which may cause conflicts if you continues"
Any help would be greatly appreciated and I can put this to bed. =D
TrippyLighting
I use two revolute joints.
e9_vito
Omg.... The way it errors and visually breaks the original joint is why I just stopped. I've 100% in the past clicked by it and it would continue to honor the new joint and break the old joint. In any case ty!
akash.nawghare
Try to create Revolute Joint between the Holes so that the other Joint can be easily get created without any conflict.
Video added for reference.
"If you find my answer solved your question, please select the Accept Solution icon"
davebYYPCU
@e9_vito  If you have sketches with a centre to centre line,
Joint the mid points (once).
Might help....
