another Joint problem
conjured2018
conjured2018
attached is a simple dovetail box. I ground to parent one end and then did an as built joint for the top and side. I then copied paste new and used joint to create the 3rd side.
I just cant use joint again to create 4th side.  I select the start point and end point goes to fade out.
thank you JR
akash.nawghare
You can use DWJ Duplicate With Joint to replicate the same component, Please find the attached video.
"If you find my answer solved your question, please select the Accept Solution icon"
conjured2018
thanks, JR
