Multiple Components - how to move and align?
ronydee
ronydee
I created 2 components.
Question(s):
1. when viewing both components, can they be separated or moved apart from each other?
2. How do I jmove and align the 2 components?  In the attached file, the PCB sled needs to  slide into the PCB enclosure.  I would think i need to do this to make sure they fit together.
New to 3d Modeling, so not even sure I'm have approach this correctly.
jhackney1972
When you place the PCB Sled into the assembly, the Pin to Parent was automatically activate.  Remove it to move component.
John Hackney, Retired
jhackney1972
If my Forum post solved your question, please select the "Accept Solution" icon to do three things. First it allows others to find a solution to a similar question, two, it closes the Forum post and last, it acknowledges that you accept the solution given. If you need further help, please ask. If you like to read why "Accept Solutions are important, take a look at this webpage.
ronydee
John thank you.
The PCB sled hole side goes on the outside. That hole is for a female stereo jack.  I'll manipulate to reverse the join  method.
Update:
Managed to inert the LCB sled corrdctly.  Took some time to understand how to rotate and get both aligned.  possibly unfamiliar with the process of aligning object.  MAybe easeier way top do  what i did, but end result got it to join both.
I'm really enthused how you address my questions, especially with the videos 👌. Great job from another retiree 🙏
