Moving / rotating components by a 3D mouse or right mouse button ?
biuroR8NM4
biuroR8NM4
Hello.
I'm trying to switch to Fusion 360 from Solidworks (10+ years of experience), but I'm stuck on one thing: can you move and rotate sub components in an "assembly" using the 3D mouse (3DConnexion) or by using the right mouse button like in Solidworks ?
I would like to have the ability to quickly move and rotate some components that are joined together with others. In Solidworks I can select a part, then use 3D mouse to drag/rotate this part. Is there a similar function in Fusion ?
Best Regards
Piotr Buczynski
laughingcreek
Nope.  Gotta use the move tool
