Moving a linked component by changing parameters in the assembly.
TomaszAdamF
TomaszAdamF
I create component No. 1, which has variable dimensions by changing parameters.
I create component No. 2.
I move component No. 2 (point to point) to the point on component No. 1.
And... Component No. 2 moves with the change of the dimensions (parameters) of component No. 1.
It should be ;-).
But...
When I LINK component No. 3 (built separately) to this assembly and move it the same way (point to point) with component No. 1, changing the parameters (dimensions) of component No. 1 does not move component No 3. Component No. 3 remains permanently bound to the global coordinate system of the assembly.
Thank you for every explanation :-).
Thomas.
lichtzeichenanlage
Assemble->Joint or Assemble->As-built Joint are your friends. Here is a simple design and a screencast what are the single steps you have to do for a joins:
TomaszAdamF
Oops. Of course. Loss of brain work ;-).
Thank you very much lichtzeichenanlage :-).
