Moved a body, sketch did not follow
Spamwall
Spamwall
I created a sketch and used this sketch to extrude a body.  I then moved the body to align with other bodies I created.  The sketch stayed in the original position.
Can I realign the sketch to the new body position so I can easily make changes to the sketch?
If I change the sketch will it modify the body correctly?
Is there a better way to do this?  e.g. turn the body into a component before moving it?
@Spamwall
You are moving  a body not a component... Convert your body into a Component.
A Component has a folder that contains sketches, bodies, features and everything else related to that component.
Try that and your Sketch should move to the same position as the component.
Hope this will help you.
__ IK
