Move Sketch without dimensions?
sal
sal
Is it possible to move a sketch that's not defined/dimensioned but keep it all grouped together?
I have a logo sketch that I'm trying to place on a part to engrave.  Naturally the logo sketch just has arbitrary dimensions.  I'd love to be able to place it/center it correctly on my part, if possible.
As is I can know how to move it around roughly in kind of a "good enough" way, but I'd love to figure out how to this better, if possible.
Thanks!
g-andresen
This depends on whether the sketch has a connection to the origin that prevents it from moving.
please share the file
File > export > save as f3d on local device > attach to post
Günther
jhackney1972
It would be nice to be able to use your model and sketch but you have not supplied it.  Here is a video showing what I think you desire.
John Hackney, Retired
etfrench
Select everything in the sketch except the Origin. You should then be able to move the geometry.
Better yet would be to put the sketch in a component, then you can freely move it about and/or use a joint to position it.
ETFrench
sal
Putting it in a blank component is a good idea, I hadn't considered that as an idea.  I'll give that a shot and see if that helps thank you!
@jhackney1972 thanks for the video, that's basically what I've been doing so far, was just trying to see if there's a way to "accurately" place the logo so it's centered in the area where I'm doing the engraving.
No perfect solution without dimensions I suppose but I'll make it work thanks guys
etfrench
Add a point at the desired center.  Select all of the sketch geometry, excluding the origin.  Use Move/Point to Point (Assumes you have a destination point defined).
If you have the sketch in a component, you may need to create a joint origin at the desired center.
ETFrench
