Move "step and repeat"
When sketching is there a way when to make copy while moving a line or instance? Like step and repeat? For example if i've drawn a line and I want to move/copy it 6 times in 20 mm in x,y,z direction. Is that possible?
I've included two image from SolidWorks to better illustrate perhaps what i'm after.
Thanks.
innovatenate
Autodesk Support
Autodesk Support
If you're actively editing a sketch, you can use copy and paste to "copy and move" sketch geometry. Another option would be to use the rectangular or circular pattern command located in the sketch menu.
I hope this helps. Please let me know if you have any questions.
Nathan Chandler
Principal Specialist
Thanks! Yes it did help. I just manually went along an copy/paste it along the way. But I like your suggestion about pattern. I tried pattern along a path.
When you use the rectangular pattern, is it possible to make each an independant line instead of part of a pattern?
Allan Steinkuhl
innovatenate
Autodesk Support
Autodesk Support
If you delete the Pattern "constraint" symbol, the patterned entities will become regular sketch entities.
Does that help?
Nathan Chandler
