Move Precision
Move Precision
r_goulter
Move Precision
r_goulter
I am working in metric mm. Am only able to achieve translate or rotate to 3 decimal place precision. Can I increase the precision?
etfrench
Set the precision in Preferences.
ETFrench
r_goulter
Appears that changing precision in Preferences does not change the translate or rotate precision. That still is limited to the Preferences precision set when the design was first created.
laughingcreek
where are you changing it? Here?
jhackney1972
You are not seeing your General Precision setting in the Move dialog, as well as other dialogs, because you probably have Hide Trailing Zeroes check.
John Hackney, Retired
GRSnyder
Also of note: Fusion 360 has a fixed internal modeling precision that's something on the order of 1E-9 cm. Anything set in the preferences is a display option only. Those settings do not affect actual geometric operations, and they do not affect your ability to enter values of greater precision than the preferences would seem to "allow."
