- Mute
- Permalink
- Report
I have a model of a concealed hinge (see https://forums.autodesk.com/t5/fusion-360-design-validate/how-to-create-joints-for-blum-or-similar-d...). It has 4 revolute joints so the overall movement is not a simple revolving around an axis. I want to set the joint limits such that the hinge is either closed (door lies on frame) or open (door perpendicular to frame). Trying to set limits "by sight" doesn't really work as the closed configuration makes the door go into the frame.
What I'd like to be able to do is to position the joint on a door/frame (with rigid groups to both) and then move the door so it lies flat on the frame and then either capture the position, or lock the joint limits (better of course sine I can then open/close the door). But the only way I know how to move is to drag with the mouse, which is not accurate, or, double clicking on the joints and setting values, which is tedious and doesn't give accurate results.
