Move Geometry Question
ARTHUR-HM
ARTHUR-HM
Is it possible to draw a circle, and type where you want it to appear on the sketch?
say X1.5 Y.5?
When I use the move tool, I see I can move it with X & Y but that is relative to it's current position. Is there a way to move it to absolute X & & of the sketch?
mike.tessier
Hi @ARTHUR-HM,
Unfortunately, the move command only works with (x,y,z) relative to the current position when enabling the move command. However, we can accomplish the desired result using constraints!
In the attached screencast, I used your example to show how you would "move" the sketched circle from its sketched position to its desired coordinates.
Hope this helps!
Mike Tessier
Product Support Specialist
My Screencasts | Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
ARTHUR-HM
Not exactly what I was hoping for, but I submitted a feature request. This will do in the mean time.
If you draw your sketch at the origin and appropriately compensate I believe the current move tool can adequately accommodate your needs. Is there a more specific reason for needing this feature?
I usually do it this way.
ARTHUR-HM
For sketching a circle, for instance, in EZCAM I can click the icon and quickly type in diameter and type an x, y, z and hit enter. It makes sketching parts based on a print rather quick. Especially a print with a lot of holes.
Is it needed? No. I've adapted to the way Fusion works just fine. All the old guys in my shop? Not so much.
