Loft with Arcs
Loft with Arcs
sukhgewanpreet.singh
Message 1 of 8
Loft with Arcs
Community Visitor
Community Visitor
Hello, I am trying to do a loft with rails, but it continuously says that my rail does not connect with the part. I have created the rail using arcs and splines. If I use lines, it allows me to do a loft, but not with arcs. Is this a problem with the user interface? My friend got it to work on his computer, so I am wondering if it has something to do with the settings or something. The points are coincident,so there should not be gaps there. Please help!!
Replies (7)
Message 2 of 8
Beyondforce
Hi @sukhgewanpreet.singh
You approach seems a bit complicated. Have you considered using a Revolve with a profile instead?
Ben.
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
Message 3 of 8
gautham_kattethota
The error message indicates that your rails are not properly intersecting the loft profiles. Note that each rail has to intersect all the selected profiles for loft with rails to work.  Alternatively, you could try using Centerline rail option (option next to "Guide Type" in the dialog), which does not have the intersection requirements that regular rails have.  But note that with centerline option you can only select one rail.
If it still doesnt work, you can attach the part to this thread and I can take a look and get back to you.
Gautham
Gautham Kattethota
Software Development
Message 4 of 8
Beyondforce
Check out the attachment, I hope that's what you are looking for 🙂
Cheers / Ben
Ben Korez
| YouTube
Message 5 of 8
Make sure your rail is really intersecting. I've included 1 that seemed to be intersecting, but after closer examination it actually didn't.
The other did and the loft worked.
Message 6 of 8
JDMather
Could you use the simple geometry of an Extrude?  (see attached)
Message 7 of 8
JDMather
...or maybe not?
Message 8 of 8
HughesTooling
@Anonymous wrote:
...or maybe not?
Why do you say that, look good to me.
Another option using an extrude cut.
Mark
Mark Hughes
Owner, Hughes Tooling
