Hello, Is there a possibility to Move/Copy, rectangular ppattern of construction Axis though 2 planes and Point at edge and plane ?
The axis and points are the fixations of joist and ribbed sheet Polyvinyl Chloride
Solved by jeff_strater. Go to Solution.
Today, unfortunately, no. In a parametric design, you cannot move or copy work (construction) geometry, nor can you pattern it. Would be nice, though.
