Move and Scale Bug
Move and Scale Bug
Move and Scale Bug
This probably has already been reported, but after the update I can't move newly created sketches or when I have inserted an svg, changed the scale with the scale function, and want to move it to a new spot, it doesn't move to the exact spot.
brianrepp
@Anonymous - Is it similar to what's been posted in this thread?  http://forums.autodesk.com/t5/design-validate-document/move-problem-in-sketch/td-p/6324722
It seems to be similar, but I tried to just drag the sketch into place, plus this happens only after I've inserted the svg and increased it's size. Also, some newly created sketches will not move at all.
I have worked my way around this by just changing the svg's size before I insert it.
