Move problem in Sketch
I tried looking for similar problems but couldn't find anything similar.
I am having problems moving my sketch. I´ve attached a video so you guys can see it clearly. When I use the Move window to move -5mm in Y-direction the Sketch moves much more than that. But if I put -1mm first and then -5mm after, it goes to the right place.
I really don't know if this is a bug or I just don't understand how this tool works.
https://drive.google.com/open?id=0BweSf-LGys-CSjM4WVFGaHZGWms
jiang_peng
Hi Manutencao,
It looks a bug. Could you please attach the f3d file here or share the design to me?
My email address: jiang.peng@autodesk.com
Thanks for reporting the issue!
Here is the f3d file
jiang_peng
Hi Mantuencao,
I logged a bug(FUS-24903). We will see what we can do.
In the meantime, I'd suggest that if you need layout the sketch elements precisely. Please use dimension instead.
Thanks for reporting this!
