morphing an object
morphing an object
mi.silva
morphing an object
mi.silva
Hello all, I'm new to Morphing, but why can I not morph (for example Edit Form) of this solid, when I clic on it it only shows lines and disappears as a solid!
Thanks all
piotr.kornafel
Autodesk Support
Autodesk Support
Hello @mi.silva
Could you briefly describe what you want to achieve?
You can try to prepare a short video with your issue, using this article below:
How to use Autodesk Screencast to document a support issue
As far as I understand you this article this article raises a similar issue: Convert Body into a T Spline
If this isn't what you looking for, let me know.
Piotr Kornafel
Global Product Support
 Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
jeff_strater
You can only edit geometry created by Form features in the Form workspace.  Your design contains only solid bodies.  What I suspect you are trying to do is just not possible (edit a solid via Form/T-Spline commands)
Jeff Strater
Engineering Director
