Adding custom title block to another sheet
darko.beretic
darko.beretic
I have problem adding custom title block to new sheet.
After I use one type of custom title block I want to use another one on another sheet but same drawing. There occur my problem, like second title block replaces first one. I used title block for A3 sheet and added new sheet with A4 title block and now its same title block on both pages.
If there is someone who is able to help me I would be thankful.
Best regards, Darko.
g-andresen
watch the screencast and try it.
günther
darko.beretic
https://autode.sk/3yWtl2K
This is what happen to me, and that is a problem which I am talking about.
darko.beretic
Hello Guenther,
I forgot to tell you, thanks for answer. 🙂
Here is link what my issue is: https://autode.sk/3yWtl2K
ClintBrown3D
Hi @darko.beretic
Your "Title Block" contains lines which look like a "Drawing Border". These 2 elements should be separate.
By default, there is a separate "Title Block" and "Border" in a drawing. You can customise the both of these.
See below:
Clint Brown
Senior Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
g-andresen
When you create a new sheet, you do not choose a title block, but a template with a title block already inserted.
In your case it looks like both templates contain the same title block.
günther
darko.beretic
It was a problem because I made Title block and Drawing border together. Now it works fine, thank you for help.
