How many Generative Design studies can we solve simultaneously in Fusion 360?
bharat.borate.27
bharat.borate.27
Hello everyone!
Hope you all are doing well...
Recently I've been working on my engineering academic project using Fusion 360 Generative Design and I came across a doubt.
"How many Generative Design studies can we solve simultaneously in Fusion 360?"
I was running generative design studies on three different files. But, only two of the studies were progressing and the third one just kept loading and didn't even progress to one outcome.
Can anyone share if they know about the maximum limit of Generative Design studies on can run through a single account?
Looking forward to hear from you all...
Bharat Borate
LinkedIn
Marcin_Kosciolek
Autodesk Support
Autodesk Support
Hi @bharat.borate.27
The assumption of cloud solving is we can run multiple studies without concerns about our local hardware. The number of studies should not be limited. I ran 5 Generative Design studies, and everything works as expected. Only in one case, I had to wait longer for the first outcomes, but that was probably because I defined a lot of manufacturing methods (I selected all available) and materials (6 different). Maybe you should wait for a long time?
Marcin Kościółek
Global Product Support
My Screencasts | Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
bharat.borate.27
Thanks, @Marcin_Kosciolek! I definitely try waiting for some time and will let know the outcome...
Bharat Borate
LinkedIn
