More Joint Confusion
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Every time I think I've figured out joints, they prove me wrong... In the attached assembly, I have an air cylinder that drives a ratchet mechanism. The position of the air cylinder body is adjustable by a pin-slot joint, which is attached to the nose of the air cylinder. A clevis attaches the air cylinder shaft to the ratchet wheel. I can get all but one of the joints to work as I want, but whenever I try to enable all of them, I get conflicts, but I don't understand how to set the joint properties to make it work correctly.
In the attached design, the ratchet wheel is locked, and the pin-slot joint refuses to resolve, apparently, at least in part, because the position of the "swivel" piece relative to the air cylinder is wrong, and that position seems adjustable only by entering a hard distance into one of the offset settings of the joint. Shouldn't it be willing to set that offset to whatever is required to resolve the revolute constraint already in place between the air cylinder and the swivel?
Ray L.
