I am still having problems getting blue lines to turn black. If they turn black at all it is inconsistent.
In the reference picture I've attached I used the perpendicular constraint at the 90 degree corners (should be obvious for F360) - and I've used the equal constraint a few places and dimensions. None of these work!
I cannot understand what I am doing wrong here.
Solved by jhackney1972. Go to Solution.
please share the file for reply
File > export > save as f3d on local drive > attach to post
günther
Here ya go - seems like plenty of dimensions and constraints and nothing but blue lines.
Your sketch has a lot of missing sketch constraints and dimensions which I show in the video. I would suggest that you left click and drag on entities to determine the missing constraints and dimensions. As I mentioned in the video, I cannot be sure of your intended dimensions due to so many problems, please check. Model is attached.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Thanks. That was good explanation - I was able to follow along and make the changes and figure out the remaining parts so the drawing is now fully constrained.
Much appreciated, I can now tackle some other drawings that need the same treatment.
