Modifying a 3D model to slice for CNC Routing.
Hello I have a 3D model that I need to modify in order to be CNC Routed.  There are some undercuts I need to get rid of and also I need to move around certain features (like the arms) such that I can slice the model at key locations.  I am very new to Fusion 360.  I know how to split the model using planes.   But I noticed that I need to move around some of the mesh based on where I want the splits so that I can CNC route from just one side of the split.  Can anyone help with this?
Mike.Grau
Hi @Anonymous,
Thank you for your Post in the Forum.
Yes, it looks like that you would have to convert your design before starting to modify it.
Could you may share a Public Link of your design that we can help you and better understand your workflow?
Thank you,
Mike.Grau
Hi @Anonymous,
Thanks again for your post in the Forum.
Please, let me know if you have had a chance to share a Public Link with me?
I would be happy to help you to modify your model.
Thank you,
wadeanres
Hi Mike,
I'm having the same problem.  I have a VW Bus 3D model and need to split it in two for CNC work.  I wpuld be happy to share the model if you like.
laughingcreek
Unless your pretty good at brep/nurbs modeling AND mesh modeling, I would not attempt to join the 2 together in  single workflow.  The sad fact is that fusion is terrible at dealing with meshes.  if all you need to so is slice the model I would suggest mesh mixer, or some other mesh modeling software.
You can also post your model here, maybe someone will help.
wadeanres
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" /><meta name="Generator" content="Microsoft Word 15 (filtered medium)" /><!--<br>/* Font Definitions */<br>@font-face<br> {font-family:"Cambria Math";<br> panose-1:2 4 5 3 5 4 6 3 2 4;}<br>@font-face<br> {font-family:Calibri;<br> panose-1:2 15 5 2 2 2 4 3 2 4;}<br>/* Style Definitions */<br>p.MsoNormal, li.MsoNormal, div.MsoNormal<br> {margin:0in;<br> margin-bottom:.0001pt;<br> font-size:11.0pt;<br> font-family:"Calibri",sans-serif;}<br>a:link, span.MsoHyperlink<br> {mso-style-priority:99;<br> color:blue;<br> text-decoration:underline;}<br>.MsoChpDefault<br> {mso-style-type:export-only;}<br>@page WordSection1<br> {size:8.5in 11.0in;<br> margin:1.0in 1.0in 1.0in 1.0in;}<br>div.WordSection1<br> {page:WordSection1;}<br><br>
