Modify only one copy of sculpt object
Hello. I just started explore Fusion 360 and have a question.
In the picture you can see sculpt body and many of it's copies behind it. I need to modify only one of them, but when I modify form in a sculpt mode, they all change. I can't modify them not in a sculpt mode, because they can't be targeted in modify -> combine.
Will be grateful for help.
Solution found.
Discussion_Admin
@Anonymous wrote:
Solution found.
Glad to see you found your solution! Would you be so kind as to post it here for other users looking for the same answer?
Discussion_Admin
I just made a copy of body in sculpt mode
How do you do this if you don't have the sculpt mode? I have the fusion 360 ultimate version
I have
