Modelling question - tension-only elements?
donzapple
donzapple
Is it possible to model a catenary support, for example, a suspension bridge cable in F360?.
How about a chain which performs in tension only?  Or a guy-wire?
I would like to be able to simulate static and dynamic performance.
Donald Gibson
John_Holtz
Autodesk Support
Autodesk Support
Hi Donald.
Since Fusion simulation only has solid elements, it is not realistic to model a cable. I suggest Inventor Nastran which has a more complete element library and analysis capabilities.
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
