Modeling a 3D Profile
Message 1 of 16
Hi guys.
Could someone help me model this piece?
I'm having trouble creating the channel in the diameter.
Replies (15)
Message 2 of 16
TheCADWhisperer
File>Export and then Attach the *.f3d file of your attempt here.
Message 3 of 16
Marco.Takx
Hi @Anonymous,
I think you mean the slot that wraps around the surface.
This is something that is not easy to do.
Inventor (Picture2) has a Wrap function that Fusion (Picture1) doesn't have.
Fusion 360.jpgInventor.jpgIf my post answers your question Please use  Mark Solutions!.Accept as Solution & Give Kudos!Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
Message 4 of 16
melvinbrian3d
this is not 100% accurate, because of the Slot but will be something like this...
MelvinBrian3D
Message 5 of 16
chrisplyler
It's a huge pain in the rear end. Open the file I've attached at the end of this post. Scroll through the timeline and examine each step.
Message 6 of 16
Thank you!!
It was exactly what I needed.
Message 7 of 16
melvinbrian3d
hey that was crazy idea create a coil and then move it to the slots points to project the touching points... i never thought about this...  and your .f3d name was accurate 🙂
MelvinBrian3D
Message 8 of 16
TheCADWhisperer
Unfortunately it is not correct.
Put a pin in it an animate the mechanism.
What do you observe?
Message 9 of 16
TheCADWhisperer
Are you sure about that?
Message 10 of 16
melvinbrian3d
could you share the correct one?
thanks!!
MelvinBrian3D
Message 11 of 16
TheCADWhisperer
I'll give everyone a couple of days to chew on it first to see what they can come up with - you might join into the effort and give it a try.
Be sure to test with a pin (representing the end-mill cutting tool translating while the shaft rotates).
Message 12 of 16
melvinbrian3d
I'll give everyone a couple of days to chew on it first to see what they can come up with.
"a Couple of Days" Smiley Frustrated O.o
MelvinBrian3D
Message 13 of 16
TheCADWhisperer
It is generally a case where the designer either knows how to achieve the correct geometry - or they quite likely will never figure it out.
This question has come up enough on virtually all of the MCAD forums that a bit of research can turn up the solution - but I challenge you to try to figure it out on your own without research.
Message 14 of 16
melvinbrian3d
i Will.
MelvinBrian3D
Message 15 of 16
TheCADWhisperer
I have already given some hints - think about the manufacturing process.
Message 16 of 16
chrisplyler
I know it's not correct. Need the ability to "sweep" a pin BODY. But it's good enough for a model representation.
If you're actually going to CAM it, Don't model it at all.  Just use the three projected legs as a path, and run an end mill down that path while the blank is in a 4th axis.
