When I right click on a joint my entire model turns black. It does not seem to affect anything other than the visual representation. When I execute a command or cancel the right click, everything returns to normal.
Has anyone else seen this?
Solved by michallach81. Go to Solution.
Hi @neljoshua,
I personally haven't seen that before, but I'm more than happy to take a look! Can you share the model with me at james.youmatz@autodesk.com and I can see if I can reproduce it on my machine? Just to check, does right-clicking any joint cause this issue or is it one in particular?
oops - looks like you reported the graphics card as: | AMD Radeon R9 M370X 2048
Do you have Bootcamp where you can try this under Windows with the same hardware?
might point to a memory or a need for Apple to get updated drivers from AMD
It's a graphic card failure. When it happens to me, I have to re-launch Fusion. But happens very rarely.
Michał Lach
Designer
co-author
projektowanieproduktow.wordpress.com
Does not seem to be happening any more.
Thanks for the tip.
