Model shadows
Model shadows
stuart.higginsA877K
Message 1 of 17
Model shadows
stuart.higginsA877K
Hi all....
I'm new to fusion and still learning especially with the cad side which is totally different to the previous software I was working on.
When I'm modelling i seem to get this annoying shadow which appears around my sketch and also prevents me from selecting the curves that I've drawn to create the model that I'm trying protrude.
Can someone explain why the shadow/outline appears and is there anything i could do to remove them...
Replies (16)
Message 2 of 17
g-andresen
please show a screenshot to see what you are talking about.
günther
Message 3 of 17
shahriarsifat1802164
Hi, can you please share any examples or screenshots?
Md. Shahriar Mohtasim
Dept. of Mechanical Engineering,
RUET
LinkedIn | Facebook | Youtube (CADs) | Twitter
Autodesk Product Users, BD
If you found this post helpful please hit the LIKE button and for a solution hit the ACCEPT SOLUTION.
Thank you.
Message 4 of 17
Are you talking about this thing?
RUET
Thank you.
Message 5 of 17
stuart.higginsA877K
Hi. Sorry for the delayed reply.
Yes that's the one.. when i was trying to protrude a model from a sketch it keeps selecting the shadow profile from a previous sketch or model and not allowing me to select the target geometry. Very frustrating
Message 6 of 17
Lennart_Losjo
Hi.
You can turn visibility on and off for the different sketches.
Senior Product Specialist
Fusion 360, Inventor.
Message 7 of 17
stuart.higginsA877K
Yes i had done that.. but when hoovering the curser over the area it would see/select it
Message 8 of 17
Lennart_Losjo
Im sorry.
Can you record a video of your problem?
Look at my video.
Message 9 of 17
g-andresen
1. Please share the file.
2. Which sketch are you talking about?
File > export > save as f3d on local device  > attach it to the next post
günther
Message 10 of 17
stuart.higginsA877K
Hi. Apologies for the delay.. as you can see on the screencast i have a rectangle visible in sketch but it is selecting the shadow from a solid which is visibly turned off..
Message 11 of 17
Lennart_Losjo
Hi.
No screencast is available.
have you looked at the video i attached in a previous answer?
Message 12 of 17
stuart.higginsA877K
Sorry... forgot to insert
Message 13 of 17
Lennart_Losjo
Still forgot it? 🙂
Paste a link to the screencast.
I have noticed that the "insert screencast" not always working.
Attache a exported file also.
attach it.
Message 14 of 17
stuart.higginsA877K
Hi, It wouldnt allow me to attach the screencast as the HTML was invalid for some reason ha!
Attached is the file.. If you hoover curser over the rectangle sketch you will see the shadow also it will select this shape when you attempt to extrude
Message 15 of 17
Lennart_Losjo
Hi Stuart.
Strange, the tree look odd.
Maby you have to copy a public link from your screencast library?
Do you have capture design history on?
Anyway. Take a look at my screencast.
When you created the sketch you got the two slots projected.
I coud not have any audio in my screencast because my headset is broke.
Message 16 of 17
stuart.higginsA877K
Ahh i see.. so even though the projected lines were not on the sketch it still recognises them.
Thank you! We got there in the end 😆
Message 17 of 17
Lennart_Losjo
Hi.
Nice to hear that.
Rock on, and hit Accepted as a solution I would appreciate that.
Regards
Lennart
