Missing geometry when projecting body onto sketch.
colingresty
Message 1 of 17
colingresty
Hi Absolute CAD noob here. I have created a body and am trying to project it's outline on a sketch, but for some reason it misses out part of the outline. Please can someone tell me what I'm doing wrong.
Replies (16)
Message 2 of 17
wersy
Without to see the body it is impossible to help.
Please upload the file.
Message 3 of 17
colingresty
Thank you, I attach it here.
Message 4 of 17
davebYYPCU
Repeatable here, no idea why, see if @Phil.E can look into it.
Might help....
Message 5 of 17
wersy
It depends on which edge you select.
Not all edges are at the same height.
Message 6 of 17
g-andresen
This is a result that occurs with complex and superimposed contours when using the ‘Body’ option.
In such cases, you can add missing parts with another projection and the ‘Elements’ option.
However, this may require some corrections.
Günther
Message 7 of 17
colingresty
I will try using the elements option instead of body. Thanks to all who replied.
Message 8 of 17
Phil.E
@davebYYPCU Thanks I let the sketch team know about it.
@wersy Thanks for helping!
(added case to bug report ticket FUS-102533)
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 9 of 17
chawl017
Any update on this issue? projecting elements is not always a viable work around and in some cases I have had effectively 95% of bodies missing when using this project option.
Message 10 of 17
colingresty
I haven't heard anything, and it wasn't mentioned in the release notes for the latest release. It is very frustrating that a really useful feature seems to be broken in this way.
Colin
Message 11 of 17
Phil.E
If you can provide a design file it will help the sketch team solve this issue.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 12 of 17
colingresty
Hi Phil,
It's the issue you added to a bug report in July
from your reply: (added case to bug report ticket FUS-102533)
File attached.
Colin
Message 13 of 17
colingresty
Hi Phil,
File attached.
Colin
Message 14 of 17
Phil.E
Thanks. When it was said 95% of the body is missing from the sketch I thought it was a different issue. I don't think this looks like 95% missing. There are two curves left out of a dozen or more.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 15 of 17
colingresty
The 95% message was from someone else replying to my original post. Do you know if a fix for this is planned anytime soon?
Colin
Message 16 of 17
pavel_viktorin
Hi, is there any progress with this issue?
Message 17 of 17
Phil.E
If you have an example, please post the model. Each case is a little different, so it helps to have more examples for the developers to work on.
(update: thanks @pavel_viktorin for the data, issue logged is FUS-190549)
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
