Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Mirroring - lost sometihng how to do it.
2 REPLIES 2
mark33.in.oz
257 Views, 2 Replies
Ok what I want to do.
The "extrusion" and two rods I want to mirror.
(Seems better than making them twice.
You can see a mid-line and where I want to put them.
But Fusion wants a "PLANE", not a line.
So....  I go off and look at the `create` options.....
I'm stuck.
To create a `MID PLANE` I need two surfaces.
And MID is the active part of this.
So what am I missing?
Sorry for all the dumb questions.   I am not using Fusion as much as I would like and want to use it so when I get to build this it will be correct.
I'm stuck between a rock and hard place with time management.
Thanks in advance.
2 REPLIES 2
davebYYPCU
in reply to: mark33.in.oz
Vertical Offset Plane o Object, snap to an end point of the mirror line,
or Plane on Angle, Using the mirror line and angle vertical.
Might help...
mark33.in.oz
Ok, after the phone call all good.
Thanks.
