mirrored components are not jointed
ND_Kevin
ND_Kevin
i want to mirror parts of a frame (profiles), the got copied, but they are still floaty, they are not constraint or jointed.
Did I miss to check a box or something?
cheers,
Kevin
chrisplyler
Any copy of a Component, no matter how it was made (mirror or otherwise), is another separate Component in the model. It will need to be Jointed into place just like any others. Or, make it a Rigid Group with the first one before it gets dragged around anywhere else.
lichtzeichenanlage
That's the reason why the Mirror feature is part of the Create menu and not of the Assemble feature. Sadly Fusion 360 has not Mirror function for assemblies. This has several implications
  • Mirrored parts and original component are listed as two different parts in the boom (even it's just mirrored for assembly and not for design reasons
  • If the original component contains a thread, the thread is mirrored, too. And that's something you often don't want to happen
