Mirror Text
Mirror Text
s.david.baxter
Mirror Text
s.david.baxter
I have placed text on a square post and then engraved (negative extrude feature) into the post, I then performed a "feature mirror" around a midplane with the intent of having the same text on the opposite surface.  It is there but the text is backward, which I suspect that is what a mirror does I need it to read left to right on both posts, in other words mirror and rotate.  I think I have done this with text in autocad but, can't seem to get it to work in Fusion.  Any suggestions would be welcome as I have a lot of posts to do each with different text, sure would cut down on the keystrokes if this could work.
I_Forge_KC
Try using the circular pattern tool instead of mirror. The axis or rotation would be the center of the post (you may need to build a work axis or dummy feature to get this)
K. Cornett
Generative Design Consultant / Trainer
henry.f.camacho
Observer
Observer
This solve the problem for me, thank you.
