Mirror lines.
Mirror lines.
potlsnekkeri
Mirror lines.
potlsnekkeri
How can i mirror the lines i have made in this file.i have drawn a constuction line for mirror plate .
i know the lines are blue as well,but cant get them black:-)
https://a360.co/41FOc8O
HughesTooling
I think your problem is you have 4 sketches and you can only mirror objects in the active sketch. So you probably should have all this in one sketch.
Mark Hughes
Owner, Hughes Tooling
potlsnekkeri
how can i get them to one sketche
HughesTooling
If I edit your first sketch and add the mirror line it works as expected. Note, you might be better off extruding one half then mirror the body rather than the sketch. Symmetry constraints tend to slow Fusion down and best practice is to keep the sketch simple and use model features.
Mark Hughes
HughesTooling
Looking closer at the design I think you should start with a rectangular box and sweep the profile around all 4 faces. See attached file.
Mark Hughes
potlsnekkeri
thanks
HughesTooling
@potlsnekkeri  You're supposed to select the post that answered your question as the solution so it might help others find it.
Thanks Mark
Mark Hughes
