Getting error when opening file
mvstimpson
Observer Observer
mvstimpson
Observer
Observer
This particular file gives errors when trying to open. When I open a different part first, then this file it opens fine. This the is error I get:
Pradipio
Autodesk Support
Autodesk Support
Hi @mvstimpson ,
Thanks for posting to the Fusion 360 Forum.
I did check the error, and this seems the x ref files are not synchronised to the cloud.
Follow the links and steps might fix the issue.
  1. On the hard drive, locally cached files are stored in the following directories
  2. In the W.Login directory you will find several folders.
    • F - this is the locally cached files stored on your system.
    • Q - this is the directory where files waiting to be uploaded are stored, also known as the "upload queue".
  3. Rename F folder name as F_Old and restart the Fusion
THANKS
Pradip Mistry
”Community
mike.lerwill
Hi, the advice above is unlikely to help, it certainly didn't help in my discussions with support.
The latest feedback that I have is that "the development team have identified and fixed the issue that is causing the problems with the assemblies".
The issue has been allocated ID FUS-128517 but to date the fix has not made it into released software.
regards
Mike Lerwill
