Midplane through a rectangular pattern
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a set of bodies created using the Rectangular Pattern tool, but the quantity of repeats is a defined parameter, not a fixed value. If I create a midplane using the outer-most planes of end bodies in the pattern then I get a reasonable midplace, but as soon as I change the parameter driving the number of repeats (a) one of those planes goes away and the midplane is now using cached geometry and (b) the midplane is no longer in the middle of the pattern.
The attached file is a very simple example.
The only solution I can come up with is to use equations to calculate the extent of the pattern based on my other parameters, which seem a bit clunky. Does anybody have a better suggestion? Thank!
