Mesh Workspace
Mesh Workspace
Mesh Workspace
I have repeatedly tried to activate the Mesh workspace following the steps but it will not appear in the dropdown. I've followed the steps and restarted the program multiple times and it will not activate. Help please
MoshiurRashid
Did you right click and select "edit mesh"?
This will active mesh workspace
Moshiur Rashid
Autodesk Certified Instructor
ACP | CSWE
https://www.autodesk.com/expert-elite/overview
LINKEDIN | FACEBOOK
laughingcreek
the mesh tab appears in the design environment when in Direct Modeling" mode (timeline turned off).  It also is available when editing a base feature, (like a mesh), because base features are DM objects embedded into the timeline.
jeff_strater
one more workflow, in a Parametric design is to create a mesh feature:
you also need to make sure that the Mesh Workspace is on in the "Previews" section on your preferences:
Jeff Strater
Engineering Director
