Problems with point to point move function - Object always jumps back
vprNXEEE
vprNXEEE
As described in the title, I can't figure out, why one of my objects doesn't stay where I'm moving it to. It always jumps back or to a random position. I appreciate any tipps or info what I'm doing wrong.
Thanks, Valentin
etfrench
Videos are nice, but it's easier to debug when the file is included in the post. (File/Export/Archive file *.f3d)
It's also better to use a joint than the Move command.
ETFrench
vprNXEEE
Thanks, I'll try the Joint Command for now. Haven't thought about it - I'm fairly new to Fusion.
I'm using a lot of linked files in this project and I'm not sure how easy it would be to export all of them for this example - maybe that's also the reason why it didn't work.
Anyway, thank you a lot for you answer, I'm going to play around more with the joint function and hope it will work out.
jeff_strater
@vprNXEEE - One important thing to note:  In the video, you are Moving a Body.  Is that your intention?  The Joint function only works on Components, so that will produce different results.  What you show in the video looks like a bug.  If you would like to share the design, we can take a look at it.
Jeff Strater
Engineering Director
sv42008
Community Visitor
Community Visitor
Unfortunately I am facing the same issue in one of my designs. I can't forward the file here, but it is definitely a bug. How do I fix this??
sv42008
Community Visitor
Community Visitor
How did you fix this?
etfrench
Make the body a component, then use a joint.
ETFrench
