Mesh problems!
Mesh problems!
graham.a.robinson
Message 1 of 8
Mesh problems!
graham.a.robinson
Hi there,
In the picture below, you can see that the file I have inserted in to F360 has a quilted appearance - where lines between panels should be sharp, they are rounded and badly defined. This seems to happen regardless of the file type (obj, stl etc). The model is a quad mesh.
Please can someone tell me what I'm doing wrong? Is there a different way I should be inserting this, or is there something I can do to recover the original shape of the model. The model displays perfectly in other programs such as Meshlab and Remake.
Many thanks in advance.
Replies (7)
Message 2 of 8
jeff_strater
You probably want to choose "flat shading" for your mesh display type in preferences:
and make sure that "Flat Shaded" is chosen here:
Jeff
Jeff Strater
Engineering Director
Message 3 of 8
graham.a.robinson
Thanks for the reply. That didn't seem to work unfortunately.
Message 4 of 8
SaeedHamza
I tried inserting a horse statue from ReMake inside Fusion 360 and the result was a little different, the reason for that is that Fusion is a quad based program
There a way I think that might get you better results, try to convert the mesh into a t-spline body and edit it
Regards
Saeed
Saeed Hamza
Message 5 of 8
TrippyLighting
Another thing that you can see in Jeff's screenshot is that he has Autotringulare meshes turned off.
If that mesh is really a quad mesh, as Speed said, try to convert it into a T-Spline.
Message 6 of 8
graham.a.robinson
Converting to T-splines seems to have got me most of the way there, thanks!
It looks like a lot of the surfaces don't join up properly or have rounded off corners, so I have tried subdividing to get it closer to the original shape. Is that the right way to go, or is there a better way?
Message 7 of 8
SaeedHamza
If you want the sharp edges, then use the crease command
Saeed Hamza
Message 8 of 8
TrippyLighting
Hard to say without the model.
