- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi everyone,
First time poster here. I am working on a mechanism for a university project and I am having trouble modelling the joints needed in order to achieve the movement I want. An example of the mechanism can be seen in this video:
https://www.youtube.com/watch?v=191Wmn9h-GI
And an example of the movement I want my model to be able to achieve can be seen in this video:
https://www.youtube.com/watch?v=8OuYhhAxe8I
For clarity, see the following image of the model (which you can find attached):
The mechanism consists of 5 bearing positions, marked with 1 on the image, which I have modeled as revolute joints using as-built joints. Position marked with 2 is direct rotation actuated by the motor which I have again modeled as a revolute joint in Fusion. What I want to achieve is to be able to grab the top surface of the pink component and rotate it at the same time around x and z-axes to imitate the movement of the mechanism and have the joints (and limbs) rotate automatically and find the position that they need to be based on that movement. I have grounded the pink and red components. After modelling all the joints, the model locks up and I can only rotate around the x-axis. I am not sure if I am doing something wrong and restricting the rotation around the z-axis or the simultaneous movement of the limbs based on the pink component's movement is too complicated for Fusion to do on its own.
Thank you in advance!
