Measurements Won't Update with Parameters
Recently Started a new project in Fusioon 360 and set a bunch of parameters, but after creating some sketches I found that the sketch dimensions are not changing when I change the parameters. They seem to be defaulting to a fixed measurement.
For example, if I set simple parameters Width 10' and Depth 5". I use those to make a box. If I change Width to 5" the sketch does not change and shows a static or fixed measurement of 10".
In any of my old projects the parameters seem to work fine, but anything new I create has the same issue. I assume it's some kind of setting, but I can't find any setting to change.
Any help would be greatly appreciated!!
