measure length of a spline segment?
bandhuA2A5Y
bandhuA2A5Y
Is there a way to measure the length of a segment of a spline? "Measure" only gives the shortest (straight line) distance between points. I'd like to get the linear length of the spline itself. I can get the total length by selecting it  (length shows up lower right in the window), but that doesn't help as I need to work with just a segment and know its length.
John_Holtz
Autodesk Support
Autodesk Support
Hi @bandhuA2A5Y
How about if you split the spline? (Draws lines that cross the spline at the ends of the segment, then "Sketch > Break") It is similar in concept to measuring the length of a "portion" of a line. You can only measure the whole length, so the line (or spline) in your case needs to be as long as the portion that you want to measure.
Alternatively, you might be able to draw a new spline on top of the segment that you want to measure, and then measure the length of the new spline.
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
bandhuA2A5Y
Thanks, I'll try that!
