Measure Diameter of Sphere
hex705
hex705
Not sure this is the right forum ... but will give this a shot.  Have done a search and not found an answer.
Is there a way to quickly get the DIAMETER of a SPHERE with the MEASURE tool? (or some other tool?)
MEASURE seems to only return AREA???  (And sometimes loop length).
In the attached image (also below) I would like to know the diameter of the blue sphere.
Clicking on it with measure returns AREA only (yes I could do the math, but why?).
Am I missing something?  Thanks in advance for your help.
steve
Replies (9)
laughingcreek
What a strange problem.  The only way I saw to do it is to create a sketch, and "project" the sphere body onto it.  This will create a circle in the sketch that you can measure.
JeromeBriot
Another workaround: right click on the sphere then "Edit feature"
Hope this helps
hex705
thanks for the tip (and the fast reply) -- that works.
steve
hex705
Thanks -- that also works.  I was using a linked file and I don't seem able to use ' edit feature' with linked files.  I can get properties -- but they basically tell me the sphere is blue.
Edit Feature does work in the source file -- but switching files to get a dimension seems unnecessary.
I appreciate both work arounds, but will adda feature request to get more info about spheres with measure.
best,
s
BaronTC
I don't have Edit Feature available in the right click menu and I don't think the sphere is 'linked'. It's just a sphere I created from a point.
etfrench
Using the Rotate tool in a sketch to create a sphere is usually better than using the primitive Sphere tool.
ETFrench
BaronTC
I'm curious as to why they would be any different? At least in a direct editing mode, anyway. Also, doing it with that method it seems I need to first create a circle, then cut it in half and then do the Rotate as trying it with the circle I get an error about the shape crossing the axis, or something like that. I don't remember the exact wording but I know I worked past it by cutting the circle in half, which itself required adding a point, then a plane of some kind or a line, etc.
etfrench
The Revolve command requires a closed profile and an axis to revolve around.  For a sphere, this means a 180 degree arc and a line connecting the arc endpoints.  The line provides the axis and also closes the profile created with the arc.
ETFrench
BaronTC
Ah, I see. So my half-sphere method was taking the long route. Thank you
for explaining the more direct approach!
