Material Issue/Bug
Material Issue/Bug
SlawsonEngineering
Message 1 of 9
Material Issue/Bug
SlawsonEngineering
I set up a custom material and solved with it a few months ago.  I am now back in the analysis and wanted to solve with new geometry and it is giving me an invalid material error.  See attached.  Did anything change with recent updates?
Replies (8)
Message 2 of 9
ahreum.ryu
Autodesk Support
Autodesk Support
Hi @SlawsonEngineering
I'm sorry you are experiencing this issue.. Smiley Sad
Could you share the custom library file(*.adsklib) and your model? I would like to reproduce it on my side.
Here is how to share your design
Is it just for static analysis? have you changed the study type??
If you change the study type, some material properties would miss. so you need to add the different material properties. but I'm not sure what happen to you.. Smiley Embarassed so I look forward to your reply
Many thanks,
Ahreum.
Message 3 of 9
SlawsonEngineering
Check your PM.
Message 4 of 9
ahreum.ryu
Autodesk Support
Autodesk Support
Hi @SlawsonEngineering,
Thank you for sharing your model.  Smiley Happy However I need your material library to check.
Would you mind trying it below?
1. Go to the "Manage materials" in the Modify tool bar.
2. Check the saved location (just hover the mouse cursor on the library name and it will showe the location)
I look forward your help
Many thanks ,
Ahreum.
Message 5 of 9
SlawsonEngineering
See attached.
Message 6 of 9
ahreum.ryu
Autodesk Support
Autodesk Support
When I open your library file, the Aluminum 2014-T6 doesn't include the properties information. Smiley Sad
When you were running with this materials, Did you get the results?
It's really interesting..because Aluminum 2024-T6 and Aluminum 5052H32 doesn't have the properties. However, ASTM A36 Beam material has included the properties.
May I know how you create the library? Comparing to ASTM, did you use a different way??
I look forward to your reply.
Many thanks,
Ahreum.
Message 7 of 9
SlawsonEngineering
I created the library manually.  I did, however, so a save-as on the design, change a few things in the model, and then try to re-solve.  Would there be an issue with this?  Or a bug?
Message 8 of 9
ahreum.ryu
Autodesk Support
Autodesk Support
I'm sorry to hear that.. Smiley Sad
I tested on my machine, but I was unable to reproduce it.. could you record our issue to see your steps??
Are you using Window or Mac?
Here is how to use the screencast
https://youtu.be/wa4bjpGJFYg
https://knowledge.autodesk.com/search-result/caas/simplecontent/content/download-autodesk-screencast...
Many thanks,
Ahreum.
Message 9 of 9
SlawsonEngineering
I have since deleted the design.  Once I can reproduce failure, I will record and post.  Thank you!
