Making white display glass
Hi everyone, I'm trying to make glass with the white backing paint/laminate you see on products like the iPhone with a white display. I don't want to use two separate bodies for the white glass part and the part you can see the LCD through, because you get interference. I put a thin body beneath glass set to the glass (clear) appearance that was set to paint (white glossy) and also tried making that body intersect with the glass. Both of these produced grey glass, not the white appearance you see on consumer electronics with white displays that looks like the white is on the surface of the glass (but isn't). How can I achieve this? Thanks!
lichtzeichenanlage
If I understand you correctly, then "Appearance -> Faces" is the magic phrase:
lichtzeichenanlage
Perhaps this one matches your problem a bit better:
